12th_Man_Fan
Jun 30, 2019Explorer
2020 GMC
Well maybe the truck builders are finally listening to the RV crowd for a change: Just got a brochure on the 2020 GMC HD trucks. 1. They have finally made the bed rails lower 2. They have a ...
Grit dog wrote:
""LEVEL" the playing field? Not sure it did much for the GM as it should have handed the RAM it's lunch on the recent IKE run"
Consider this.
Ram, 1000ftlbs and puts almost the same hp to the wheels as a L5P despite being down some 40hp. 4.10 gears. 6 speeds
GM, almost 100 ftlbs shy of the Ram at 910 and saddled with 3.42 finals. 10 speeds
In general, the additional gear splits should have helped the GM make up for less torque and higher final gear ratio.
That's what I meant by leveling.
