12th_Man_Fan
Jun 30, 2019Explorer
2020 GMC
Well maybe the truck builders are finally listening to the RV crowd for a change: Just got a brochure on the 2020 GMC HD trucks. 1. They have finally made the bed rails lower 2. They have a ...
Huntindog wrote:
Visually I see 2 maybe 3" MAX in the video. They did state that GM used the position of the axle on the springs and the shackles as their reasoning for the change..
Which goes along with my theory...
Makes no difference though. We already KNOW what the result is due to the CAT scale tickets.
100#, so do some backward computations until you arrive at a method that matches the result.
That will be the correct method.
As an aside, banter on GM forums is that this move was only for the SB/CC models.
It kind of makes sense, as that configuration could benefit from such a change.
