Lantley
Oct 18, 2019Nomad
ib516 wrote:
When I ditched diesel and bought a 6.4L Hemi, cost was only one thing I considered. The reliability of diesels at the time was suspect (2013 ish), and the DPF/DEF issue was something I didn't want to deal with. Most around here with trucks of that vintage have removed the emissions junk now as they tend to be troublesome when mileage creeps up, and since we don't have mandatory emissions testing.
I had about a 10 mile commute at the time, and neither of my diesels ever got to operating temp in 10 miles at -25 to -30*C or colder, even when the grill was completely blocked and they had been plugged in, inside a garage before starting. I froze every day driving to work. My use case would have killed a DPF equipped truck.
I also only towed (actually had the trailer behind the truck) for 5-7 days a YEAR. Yes, we took 3 week vacations, but that was usually 2-3 days total towing. Some trips were less than a day.
The 6.4L Hemi towed my 12k 5er with no issue at all. The mpg was about 30% less than the diesel it replaced, but unleaded is, and was cheaper than diesel fuel where I live (Canada).
The premium for a diesel over a gas truck in Canada is closer to 12K, not 9K.
I was very happy with the big gasser I had.
Now, if towing performance is the only data point you look at to compare trucks, the diesel will win every time, as they out perform the gassers when it comes to towing power. That is a fact. For me though, that was NOT the primary consideration. I was evaluating the truck based on the other 360 days of the year when I used it for personal use, and for that, the gasser won hands down.
In general I agree with your point in that it's about performance, however where we somewhat disagree is that this is a "tow Vehicles" forum.
My thoughts are based on the idea that the vehicle is used for towing.
I understand the vehicle may have other uses/duties but none of my comments or the commentary found on a towing forum are directed towards the other duties.
Does a diesel make the best: grocery getter, commuter car, or kid shuttle? No but those factors are not what we have in common on the towing forum.
The advice and info you will gain on this site applies strictly to towing. Those other factors are not pertinent when it comes to the tow vehicle discussion.
