ShinerBock
Apr 11, 2020Explorer
FishOnOne wrote:ShinerBock wrote:FishOnOne wrote:
I never said the CP4.2 is a second generation pump.
Also for the Cummins setup now with a overdriven CP4.2 go look at the number of teeth on a CP3 setup vs a CP4.2 setup. The CP4.2 is now being turned alot faster than a CP3 and even faster than the Ford setup. By turning the CP4.2 even faster I can't imagine that's a good thing.
This is news to me and I would have to verify. What rpm is the Ford pump running versus the Cummins?
Here's some information from Firepunk on this topic at the 2:00min mark. Noticed they also had to install head studs at this power level.
Link
LOL, that is all new CP4 pumps and is one reason why it puts out higher pressure than the CP3 and even gen 1 CP4's on the older Ford's and GM's. I know Lavon(he actually made one of my tunes for my truck) and I know he hasn't had a 2020 PSD in his shop yet to even compare the two to know whether or not it turn more than the new 2020 PSD. So he is comparing to older CP4's which maxed out at 29,000 psi and Ford used every bit of that pressure(to make more power). The old CP3 Cummins maxed out at 29,000 psi, but Cummins only used 26,000 psi.
It also appears that I was incorrect on it being a CP4-27. From the looks at it from Bosch's website, the Ford and Cummins is the CP4-25 variant which maxes out at 2,500 bar or 36,000 psi. However, Cummins only utilizes 29,000 psi from the pump and Ford uses all 36,000 psi of it's max pressure. The CP4-27 is for larger engines.
LINK
44,065 PostsLatest Activity: Apr 14, 2026
