ksss
Apr 11, 2020Explorer
Cummins12V98 wrote:blofgren wrote:Cummins12V98 wrote:
Has ANYONE heard of a 2019 or 2020 RAM/CUMMINS Bosch fuel pump failure??????
Same with FORD??????
Yes, there was a 2019 Ram/Cummins failure; I'm sure Fish has it bookmarked. :B On one of the Ram forums, there was a tech saying that he fully expected to see them fail.
As for 2020's, it is likely too early to see any but I'm sure they're coming.
Given the risk of this disaster, there is no way that I will ever own a truck with one.
Ok so that’s one. Was there any follow up as to if it was the pumps fault or possibly someone dumping DEF in the fuel tank.
I am a member on the TDR, not a peep.
Cummins12V when Cummins was using the CP3 it was a main talking point of yours as one of the major advantages of the RAM. Now that Cummins has a 4, you ask for proof its not a POS. You never accepted that in the years before. A CP4 was poop, plain and simple. I think at its worst the 4 had what...2% failure rate in FORD and GM? Costly as hell if the warranty doesn't pick it up, but a rather small failure rate. Yet you played it like a fiddle. Now you take the exact opposite side when RAM takes the CP4. Consistency is a major part of credibility.
44,065 PostsLatest Activity: Apr 14, 2026
