1320Fastback
Jun 10, 2019Explorer
RoyJ wrote:
To put things in perspective - the might Dodge Ram Cummins 6BT debuted in 1989 with a whopping 160 hp, and ground-breaking 400 lb-ft. It also had a class leading 16,000 lbs GCWR.
Now we have 100 more hp, and 80 lb-ft more torque, in a 1/2 ton diesel, coupled with a MUCH better transmission.
The nice thing about the old ones though is you can turn them up quite significantly and even more so with a pump swap. Also the cooling systems were designed to run at full load. Factory transmissions did leave something to be desired though and were the weak link in stock form.
