Grit_dog
Jan 05, 2021Trailblazer
4x4ord wrote:
7 th gear is 1:1 in the 10r140 and 6th is 1.277:1. So a downshift at 2114 rpm in 7th brings the engine speed to 2700 in 6th. 5th is 1.519 :1 so dropping from 6th at 2270 rpm would bring the engine up 2700 in 5th.
I hadn't looked at the ratios in a while. But looking at it, I'd drop 9th or 10th gear like a bad habit and stick with only 2 OD ratios and insert another gear somewhere between 4th and 7th, where the trans will spend most of it's time when loaded heavy.
400-500 rpm splits are great. About 100% better than my old 6 speed manual Dodge that was a challenge to get the next gear rolling before you lost 1000rpms.
But personal opinion, I'm not the guy who likes to see how low I can go on the tach and still get a load up a hill, because I've owned a couple EGT gauges and me and the EGT's are both much happier putting a few hundred more rpms through the input shaft. Thus, I don't need 3 OD ratios in a pickup truck, especially if it's not a 4.10 final ratio.
All good discussion! And pertinent to your torque rise examples. What if you could split that torq rise in half or even knock 30% off of it? Bingo, you're sitting at peak power availability more of the time. Whether you need all of it or not.
Which also helps with bsfc.
