4x4ord
Jan 08, 2021Explorer III
Towing 63 mph I’m at 1750 in 5th and putting out 600 Nm (110 Kw) or 1432 in 6th putting out 733 Nm (110 Kw) and getting the 9 mpg.
70 mph empty we are both at 1594 in 6th getting 18 mpg putting out 333 Nm. (55 Kw)
Pulling a 7% grade I’m able to do 45 mph at 2170 rpm putting out 1277 Nm (290 Kw) and according to the bsfc map I should be using 205 g/kwhr which would put me at 2.44 mpg and again you’re not going to do any better.
Edit: I'm barely into the bottom of the dark blue at 63 mph/1750rm and 600 Nm ... so probably 200 g/kwhr 9.22 mpg
just outside the dark blue at 1432 rpm in 6th and 733 Nm
.... so maybe 205 g/kwhr or 9 mpg
At 63 mph your at 1569 rpm in 8th and 669 Nm. So 195 g/kwhr/9.46 mpg
