4x4ord
Jan 12, 2021Explorer III
^^^ I figure a Ram towing a typical 20,000 lb toy hauler should get around 9 mpg at 62 mph. If you use the BSFC map that we have and figure the Cummins will be running in the 205 g/kwhr area of the bsfc map we can come up with the kw required to tow a 20k trailer at 62 mph. 9 miles per gallon is 22182 grams of fuel per hour. 22182/205 = 108 kw or 145 HP. From there you should be able to come up with what you think are reasonable numbers for surface area, rolling resistance and coefficient of drag.
(Keep in mind that the calculated power requirement is at the crankshaft so rear wheel hp would only be about 123 to 125 hp.)
