ShinerBock
Jul 15, 2020Explorer
FishOnOne wrote:ShinerBock wrote:FishOnOne wrote:ShinerBock wrote:FishOnOne wrote:
For our off road and daily driver needs a IFS could be the ticket, but will need to test drive to confirm. I would like a soft long travel suspension which it appears how the Bronco is setup.
We came close to pulling the trigger on a Jeep Wrangler but with a few things we didn't like about it, and knowing the Bronco was coming we decided to hold off. Based on what I've seen we made the right decision.
The Bronco doesn't even have a mid-travel suspension let alone a long travel suspension. Heck, even the Raptor doesn't have a mid-travel suspension, but it is very close. If you are gonna use this vehicle as a daily/mall crawler that is not going to do any heavy rock crawling then IFS is the way to go. It will be noticeably smoother than a solid axle Jeep that you would have to throw a grand or so into for the same smoothness. If you do decide to take it on some serious trails, then make sure you bring along spare parts and/or upgrade to stronger materials if they have a lot of miles on them.
I'm sure there's plenty of Rubicons at the malls and I'm sure this Bronco will be more than capable of handling my dirt roads and pulling my 22ft bay boat. This vehicle will be my wifes daily driver as well so no routine rock climbing here. :W
I never said there wasn't Rubicons used as mall crawlers. Heck, Jeepers made up the term for other Jeepers that had bought off road rigs, but never take them off road or use them for what they were built for. Just like people who buy trucks that never haul anything, sports/muscle cars that never go to the track, or sedans that never carry more that two people.
All I said was IFS is a better choice if is is going to be used as a daily/mall crawler because of its comfortable that a sold axle(in stock form). This has nothing to do with brand, and I am not sure why everything boils down to brand in these conversations.
It is like you are taking me saying that IFS is not ideal for my kind of off roading as a personal assault to your preferences or how you will be using this vehicle. Is it because I pointed our a flaw for my preferences in a Ford product and you feel that you have to defend your brand? If this is the case I assure you I say the same about other IFS vehicles meant to go off road like Jeep Cherokees and Ram Rebels.
Per this video the Bronco will have class leading suspension travel with 10" in the front and more than 10" in the back. So I would say this has long travel suspension IMO.
Link
So this is why you are taking it personal? Because I said something that didn't go along with what your brand's marketing department said?
Long travel suspensions generally start around 17+ inches of travel in the front/rear and are very hard to drive on road. Mid travel is around 14-16 inches of travel in the front/rear which depends on the vehicle. In order for this Bronco to have a long travel suspension, it would have have to have a wide footprint because the control arms would have to be much longer(probably longer than what can be legally driven on road). This is why all long travel vehicles have wide and tall fenders to keep the tires from hitting them as they travel up.
If the Bronco had a long travel suspension on it, it would tear those stock fenders up seeing how close they are to the tire especially on the 35 inch tire models.
I also don't care too much about the stock specs of anything because I like to modify my vehicles which is why my JK Rubi has over 22" of travel with it's Metalcloak suspension that cost me around $2,600 and I was able to put it on in a day. It would cost more than three times that amount to do the same on an IFS system and would require some major modifications. All I had to do is trim my fenders a little our buy new ones for about $300-700. Here is the amount of travel that just a 2.5 inch lift can add to an solid axle for just $2,600 on a very minor obstacle (LINK). An IFS would be teeter tottering with only one tire on the ground up front on a simple obstacle like that.
If you want to see what it takes to make the Raptor a mid-travel(from 13 to 16 inches) and what it does for the truck, then you can look at the parts and video in this LINK. The Bronco would have to replace its hood and fenders(like the stock Raptor has) to get the same type of travel because the longer control arms would make the tires stick out much further. On a solid axle, you don't have to widen the whole suspension in order to get more travel like you do on an IFS.
