Gdetrailer
Oct 03, 2021Explorer III
JIMNLIN wrote:
I big rig trailer repair shop can bend the axle back to specs and have you on the road in short order.
Rolling over a curb at 5mph ?
That quite a impact especially if the trailer was going around a corner and with the tires side scrubbing "into" the curb.
One of the two big rig trailer repair shops I've used said they see lots of lead axle/curb side bent wheels and axles....cut tires or just outside rubber cuts on rv trailers.
A bent wheel won't bend a std leaf spring suspension axle. Jack the wheel up enough to roll it by hand. If it wobbles its bent and needs replaced....and have that tire checked internally.
OPs trailer from the manufacturers brochure says it has Torsion axles.
A bent or out of round wheel has the potential to cause considerable stress to a torsion axle at high rates of speed from excess bouncing. But I sort of doubt it was the main cause of the axle damage but may have been a contributing factor..
I seriously doubt any repair shop whether it is a big rig or small mom and pop can fix a torsion axle once the rubber has been damaged which is highly likely what gave out since the rubber in a torsion axle is the weakest link.
Op mentioned it is a single axle so "scrubbing" as you would know from dual or multiple axles does not happen..
I suspect that the axle the OP may be a 3500 lb rated axle, OP should be able to determine that easily by counting the lug bolts holding the wheel on..
5 lugs/bolts will typically be a 3,500 lb axle.
6 lugs/bolts will typically be a 5,000 lb axle..
One would hope that the manufacturer put a 5,000 lb axle under there..
I suspect the OP has 5 bolt rim and that would mean it would be very easy to overload that single axle in a hurry since the manufacturer claims the dry weight is just a couple of pounds below 3,500..
If it is a 3,500 lb axle and with a trailer GVWR rating of just under 5,000 lbs that means all but a couple of cargo pounds must be bore by the hitch in order to not overload the trailer axle..
