blofgren wrote:
Exhaust brake - I played around with the settings on it, and even in full on and the transmission in tow/haul mode, it worked OK, but definitely not nearly as strong as the one in my Ram/Cummins. I would estimate it to be about half as strong, but I suspect that the one in my truck is super strong due in part to the manual transmission.
Well strength is partly based on the gear the transmission is in, likely the auto was a gear or two higher than what you descended the hill in.
I find the EB on our 2016 Ram to be slightly less aggressive than the PacBrake I installed on our 2001 Ram 2500 5.9.
