- blt2skiModeratorYes Fish, he had a trans on the floor. Worked fine!. But had an oil leak in gasket. Took in to fix before warranty went out. Mechanically, worked fine. Both of you are stretching the truth some. IMHO, both of you are also false in comment. Get over it.
Marty Cummins12V98 wrote:
MFL wrote:
4x4ord wrote:
^^^ It’s not posted as fact anywhere as far as I know….. it’s just me thinking it’s pretty tough to compete in a 500 HP/10 speed market with 420 ponies and 6 gears.
"the 2023 Ram is apt to take a big hit in depreciation when the ‘24 comes out with 8 gears and 480 horsepower / 1200 lbft of torque."
You will lose credibility by making these type statements. If you would have said guessing, or if, in that remark, you wouldn't be providing false info.
Yes, you did clear that up, after being confronted.
Jerry
OUCH!!! That even hurt me Jerry!!! :B
He is actually the one that said the 6 x 6 is just fine and would not make much difference with more gears.
As mentioned WHY in the HE!! change when you have combo's that do the job reliably.
I will repeat, I tow way more weight than most anyone here at 35k combined West Coast and have ZERO reason to want more gears or power. I have owned both trans and I love them both.
The one you felt inclined to install a after market oil pan or the one on the shop floor? I'm confused... :B
The 68RFE
The almighty Aisin that doesn't break
- MFLNomad II
Jerry
Harsh...not intended. Just a tip for a respected member, that many trust to be stating facts, when in this case it wasn't. Good that you asked him!
My opinion...I agree, with the Ram not NEEDING more than a stout 6-speed. I do think similar to others opinions, that since technology continues to advance for Ford/GM, at some point Ram will follow. Right/wrong, it will be considered upgrading the drivetrain and body/frame/styling.:)
Jerry - Cummins12V98Explorer III"And noise level by running lower RPMs."
What NOISE LEVELS??? Never heard the newer RAM's called noisy. - Cummins12V98Explorer III
Jerry
I will repeat, I tow way more weight than most anyone here at 35k combined West Coast and have ZERO reason to want more gears or power. I have owned both trans and I love them both. - Cummins12V98Explorer III
FishOnOne wrote:
Plus Ram is way overdue to update their HD trucks to the new body style.
You mean like ford on the last LONG run??? - MFLNomad II
Jerry - Bionic_ManExplorer
FishOnOne wrote:
Bionic Man wrote:
In before the "RAM doesn't need more gears" comment......
It sure would help with improving fuel economy.
And noise level by running lower RPMs. And the simplicity of only having ONE transmission for their HD line. And getting competitive in HP/TQ in the 2500s….. Bionic Man wrote:
It sure would help with improving fuel economy.- Bionic_ManExplorerIn before the "RAM doesn't need more gears" comment......
