Huntindog
May 24, 2023Explorer
Jack in Dixie wrote:If you are thinking of 16" rims, that may not be possible. In at least some cases the larger rims are needed for the larger brakes. No ideas if this applies in your case. Just something to check on.
Both OEM NEXEN front tires (LT235/80R17E) had to be replaced last week due to separation with only 11K miles since I purchased the truck FEB-21. Wish I had known (or researched) these POS tires before I signed on the dotted line or I would have insisted on Michelin Defenders I have always used in the past before I left the dealership. My bad...
I have ZERO trust/faith in these NEXEN tires. Therefore, I am going to remove/replace these crappy tires this week. My problem is finding a Michelin Defender LTX M/S or Michelin LTX M/S2 in my OEM size tires (LT235/80R17E). Only Michelin tires I can find in my size are the LTX A/T2, Energy Saver, and Agillis???, none of which I really want to pay $2K for. I NEVER had so much as a flat tire in the the 20+ years I rode on Michelin Defender LT tires hauling RVs around the USA!
Is there another SIZE TIRE that will fit on my 17" wheels so I can try and find a Michelin Defender LTX or LTX M/S set of tires? If not, looks like I will be buying new wheels also...
Thanks in advance.
Jack in North Florida, Retired
River Life on the beautiful Suwannee River
2021 RAM Big Horn 3500 DRW CC/LB 4x4
2021 Keystone Cougar Half-Ton 29RKS
