cummins2014
May 25, 2023Explorer
Cummins12V98 wrote:Learjet wrote:Cummins12V98 wrote:Learjet wrote:
38,000 miles on my Michelin LTX MS2 tires and they have been great and are wearing great!
I assume you had your front aligned to nearly ZERO toe???
No alignment changes...still set from factory.
I have seen your post about that...but I never had an issue with wear on the front tires. I do rotate the front tires only side to side every 10,000 miles. All good so far :)
VERY interesting!!! Are you the original owner?
I had my truck set to the Thuren specs after the drag link recall replacement from whatever it was to near O toe. I too have never had any unusual tire wear prior to this alignment , hope that doesn't change ,setting to these Thuren specs . This is my third set of tires .
Not sure how much water this holds ,this near 0 toe . Been hearing this since I've owned the truck . We will see . I see no difference in handling , road wander etc . This is the first alignment my truck has had since new , 9 years . Not sure why, mostly because I had the drag link replaced .
To add my son is on his third Ram since 2008 , and its used daily for work ,lot of miles ,and he's never had one of his trucks aligned ,and again no unusual tire wear . Beginning to wonder about this 0 toe thing . Kinda funny that the manufacturer of these trucks don't set the toe to nearly 0 ,makes you wonder .
