JIMNLIN
Jan 02, 2016Explorer III
You may want to do some research on compatible materials for "gluing" the roof skins to the luan which eliminates roof rumble while traveling and on windy days. Roof rumble = rippling/waving of roofing material in areas not glued down.
I've found metal roof material that is glued down doesn't shrink with cold and swell with heat as a non glued metal roof material. This constant movement is hard on the material in areas that are fastened permanently to the roof ie (roof vents/vent jacks/etc).
We all have seen RV trailers going down the highway with a rubber roof flapping just behind the front cap (ballooning). Aluminum roofing material reacts much the same when not glued down properly.
44,071 PostsLatest Activity: Aug 30, 2026
