cooldavidt wrote:
Hi
I live just north of you.
I too am looking upgrading from OEM to a higher rated tire/rim combo.
My OEM LT tires and rims are both rates at 3140 each. On a 2015 F-250
Last w/e i weighed myself in Bellingham by the airport. I am slightly overloaded on a gross basis.
My LT245 75R 17 121/ tires are Load Range E and the 3140 is written into the sidewall at 3140 lbs.
What were your original tires and rims capacity?
Would you share your total cost for this install?
The old tires were rated at 3200lbs each and I was running 6500lbs on the rear axle, not sure on the rims they were factory. I got the Vision wheels at Summit Racing for $728.00 with free shipping and Les Schwab charged me $1760.00 out the door mounted and balanced.
They even removed the TPMS sensors from my old wheels so I would not have to buy new ones and got me a spare tire the same diameter as the new tires on one of my factory rims.
