- ktmrfsExplorer III
donn0128 wrote:
No. Perfectly normal. Tires are designed for that situation. Sidewall lists max COLD presdure.
exactly. Gases (air) follow Boyles Law for a constant volume (which a tire basically is) pressure is a linear function of temperature change. And on a hot day internal tire temperature can easily be 120-140F.
That's why instructions always say to check or inflate tires after they have set for several hours to get to outside temps. - Campfire_TimeExplorerX2! Don't let air out, you'll be running them under-inflated.
- donn0128Explorer IINo. Perfectly normal. Tires are designed for that situation. Sidewall lists max COLD presdure.
44,056 PostsLatest Activity: May 04, 2014
