Huntindog
Mar 28, 2022Explorer
Cummins12V98 wrote:I di not say it accounted for all of it. But there are many differences, and they add up.Huntindog wrote:rhagfo wrote:The 500 LBS is mostly due to it being a higher trim level.... Which will actually work against it in the performance attributes of this test.cptqueeg wrote:
Payload was much different and somehow it was overlooked in the recap.
They did touch on the difference in payload, that the Ram was a true 3/4 ton the Chevy was a one ton labeled as a 3/4 ton with a GVWR of 11,300# if I heard correctly. The Chevy was also 500# heavier than the Ram.
What about the higher trim would add 500# ?
44,071 PostsLatest Activity: Aug 16, 2026
