Roadtech
Dec 24, 2013Explorer
2500 or 3500?
I plan on buying a new Chevy Duramax, crew cab, short bed, 4x4, either 2500 or 3500 truck. I will be towing a 10,000 lb GVWR travel trailer (bumper pull). I plan on installing a 50 gallon Transfer Flo...
Roadtech wrote:
I plan on buying a new Chevy Duramax, crew cab, short bed, 4x4, either 2500 or 3500 truck. I will be towing a 10,000 lb GVWR travel trailer (bumper pull). I plan on installing a 50 gallon Transfer Flow in bed diesel fuel tank. Both trucks have conventional towing capacity of 13,000 lbs, but the 2500 payload is 2706 lbs and the 3500 is 4125 lbs. Do you think I would be ok with the 2500's capacity? Also, does the 3500 ride quality any different from the 2500?
