I am buying a Ram Outdoorsman crew cab with the 6.4 Hemi and 4.10 axle. The Ram website states the payload is 2926. Does anyone know if this payload is true? I worry there is some small print or some...
It should be around that, gas 3/4 tons usually will have higher payload then their diesel version. My truck has 2997 lbs payload where as the same truck with the diesel is around 2500 on my buddies 09. Due to the heaviness of the engine is the reason. And like others said the door jamb is the most accurate guid to go by.
