DakotaDad
Jul 06, 2016Explorer
I've got a similar setup, a 2016 Ram 3500SRW, and a 2015 Sabre 33RETS. Your dry pin weight is about 100lbs more than mine, and your GVWR is about 1500lbs more than mine, so they're not ALL that far off on weight.
Mine settles just a bit hooked up. Levels it, basically. Doesn't sag at all. Never wallows or bounces. Tows perfectly. I wish it would settle just a tiny bit more, actually, as I'm just a hair nose-high on the fiver. Unless you somehow load yours to be obscenely nose heavy, I wouldn't expect you'll have any problems at all.
