kohldad wrote:
One thing to keep in mind is if you ever get pulled and weighed, they are going to compare your door tag to your actual weights. If the actual weights exceed your door tag, you will be given a ticket, forced to remove weight until you are under your door tag, and only then be allowed to proceed.
Granted, I've never heard of a TC being pulled and weighed. But you may want to verify if traveling to Canada. Also heard something late last year about RVs being required to weigh in PA, but couldn't find anything on a quick search.
Thing is, that door tag also lists the tires that weight rating is valid for. As soon as you change to a different size tire that door sticker is no longer valid.
