Me Again wrote:
Let experienced drivers manual select the gears both going up and back down. Then you will learn a lot more about each truck. Number of brake applications down hills should be greatly reduced.
Agreed! I can tell you my last RAM 11 HO Dually towing a combined 29K with 3.42's I could manually drop a gear at times and get it to gain some speed while on a grade. The AISIN knows exactly where to be as I have tried dropping a gear on grade and it did not make one bit of difference in speed.
Only thing I may do is if I know I will be dropping a gear on grade is to do it just before my speed starts to drop. I mostly tow with cruise on up and down grades and on the flats.
When descending I choose the gear I would have came up the grade in. I set cruise for the speed I want to descend but most of the time I am set to a few mph slower than I want to maintain. I rarely touch my service brakes even when double towing at 35K combined.
Bottom line you can make these trucks perform best with a little help from the educated driver!!!
