Cummins12V98 wrote:
IdaD wrote:
I don't know why people care 10 pages worth (to date) about a Cummins being 2 seconds faster than a Powerstroke up an 8 mile climb pulling more than most of us will ever pull. I'm sure the Duramax would be right there with them if it was rated a little higher too. From a towing performance standpoint you really can't fault any of the diesels and that's been the case for quite a few years.
A couple seconds make ZERO difference. What is very interesting is RAM PULLED THE SAME with much less advertised HP.
But with essentially the same torque. The drag race where the Power Stroke was able to achieve higher rpms is where you seen the higher HP.
Bottom line the higher HP Power Stroke is a much better daily driver and towing up a major incline the performance is essentially the same.
Link
