I once had an '02 Chevy with a gas engine. I wanted to install a second battery. I ordered the tray, wiring harness, and relay form the Chevy dealer and installed it just like factory. The relay is used to disconnect the second battery when the engine isn't running.
After you install this battery you would want to take the 12 volt charge line that runs to your 7 pin connector and connect it directly too your second battery. The wire is currently connected to the underhood fuse box so it's easy to get too.
You would also want to install a deep cycle battery in the tray; not a starting battery.
