pbeverly's avatar
Jan 19, 2019
2nd Trip and Major Issues
1. Awning extended fine. Bad weather later today so I want to retract. Hit the button, nothing, motor does not fire up. Did not over extend.
2. Water worked great at hookup. Now, all water works except kitchen, it dribbles. Took head off, no blockage.
  • We had the same problem with the kitchen faucet...dribble. Took the aerator off, no problem since; good pressure.
  • 1. Use the troubleshooting information found in your awning manual or online.
    2. Did you remove the strainer at the tip of the faucet? Don't understand what you meant by taking the head off.
  • I can’t help with the awning, but about the water... is both the hot and cold a trickle in the kitchen?
