boingram
Nov 11, 2014Explorer
2wd vs 4wd
Hi all...time to open another can of worms...we r going to purchase a 2015 2500 denali duramax crew...just don't see the need for 4wd...how abt some non male ego driven opinions on the subject. ..thx...bo
brulaz wrote:Grit dog wrote:
You're completely misinformed on most accounts here. The last 4wd transfer case that didn't act well on dry pavement in 4wd was the NP 205 in early 80s pickups. Maybe some jeeps for a few years after that. Any new or newer 4wd can be driven as far as you want in 4 wdh on dry roads, however unnecessary.
My 2009 Tacoma 4x4 could not. You could feel the heat and smell the stink if you mistakenly left it on for a short while on dry hard roads.
And according to Ford F150 manual: "4WD should not be operated on dry pavement; driveline damage may occur."
The higher end F150s have a "Full-time 4x4" or AWD that can be left on all the time.
Brisk wrote:gafidler wrote:
the best thing about 4 wheel trucks is they can be pull by a 2 wheel truck when they get stuck.
Yeah, Ok. That's close......
wnjj wrote:Ditto x10!RedRocket204 wrote:Bedlam wrote:
If you drive using engine braking more than using your service brakes, 4wd does handle slowing better on adverse surfaces.
Bedlam. 100% agree with you. You are not saying 4x4 stops you better, you are saying it helps slow you better while maintaining traction. Seems a lot of people don't get this...and I guess the experts who disagree all live in parts of CA that doesn't get snow or ice. I guess their experience trumps all.
Ditto. It's like the difference between braking when in gear or neutral. Driven wheels are simply harder to brake quickly (and lockup). If you stand on the brakes, all bets are off and there is no difference. It matters when you ease on the brake or let the engine do the braking.
ford truck guy wrote:
Having a 4X4 makes it HARDER for me to stop.... That's because having 4X4 allows me to go faster in bad conditions , thus making it harder to stop! :B.. In reality , IF ANYONE tells you that a 4X4 stops better they have co clue !! I have a 4X4 only because when my truck is not towing it is sitting,,, when it is not towing OR sitting , it is doing snow removal which is harder with 4X2...
Bedlam wrote:
You just hit the button on why you see so many 4wd's in the ditch. Many drivers do not realize how bad the conditions are when traveling in 4wd until they try to brake. If you are passing a number of 2wd's in your 4wd, you are most likely driving too fast for conditions.
