KKELLER14K
Mar 09, 2019Explorer II
This is a wood block alignment. Sorry, I don't have any more pics..but it is a 4x6 bolted to a wood 2x6 in the front. Take those rubber things off before you jamb your cab with the box...the board across the bottom keeps it from sliding forward... the alignment blocks center it in the box. They are cut at an angle with a 1 inch flat spot at the bottom so when you lower the TC it keeps every thing centered and aligned. It might be hard to see but the blocks are also angled for alignment when lowering it into the box...the tolerance is an 1/8 inch side to side...if I find more pics I will repost. BTW notice that even though It has a Linex, I still use a rubber mat..
44,056 PostsLatest Activity: Dec 27, 2025
