puma_28dbExplorerMay 18, 20133.21 vs 3.55Ram has built a number of 1500s, 5.7 hemi's with the new 8spd trans. Some or most of them have the 3.21 gears. The tow rating is about 2,000lbs less than the same truck with 3.55s regardless if the tr...Show More
GMT830ExplorerMay 19, 2013Lower gears are always better for towing. And the Hemi builds better power much higher in the RPM range.
Related ContentRam 3.21 rear end towingRam 1500 3.55?F150 3.31 gears vs 3.55 gears2016 ram 1500 mpg 3.21?Difference between 4.30 & 3.55 gears
