4x4ord wrote:
ShinerBock wrote:
^^^ At the risk of starting another drawn-out debate. There is way more into why taller rear gears put more stress on the trans/driveline especially when towing than just engine hp/and torque. I will leave it that.
I guess if you’re having problems with failing driveline components and you want to speed things up to reduce you’re high maintenance costs you better do that. I don’t think I’ve even had as much as a u joint fail in the last 20 years on a pick up truck.
(Even though I know this was a passive-aggressive jab) I am not having any failures and have not had one u-joint replaced either in 140k miles, but the fact still remains that a taller rear gear ratio puts more stress on the transmission and driveline, especially when you tow in higher gears.
