4x4ord wrote:
ShinerBock wrote:
4x4ord wrote:
Lynnmor wrote:
Obviously some don't care, but hopefully an intelligent discussion won't use the who cares attitude. Some want the best for their equipment, there is no need to talk down to them.
I wouldn’t say “who cares?” But I think it is an honest question to say “why would a person care?” Will the Ford driveline last longer transmitting 200 hp at 2400 rpm than it will transmitting 200 hp at 2000 rpm?
Yes, the transmission will have a much greater chance of lasting with shorter gears. Just about every 6R140 through our nine Ford dealerships with burnt or grenaded overdrive clutches was with a taller gear ratio and/or heavy oversized tires.
If what you’re saying means anything it would lead me to wanting 3.31s in an f450. You need to think about what you just wrote.
Shorter gear ratio = higher numerical number. Taller rear gear = smaller numerical number. This is the basics of truck ownership(especially if you own HD trucks) and I am not sure how you are getting confused.
