ShinerBock wrote:
RoyJ wrote:
ShinerBock wrote:
Is this driver error? There are arguments for both sides, but I, like the OP, choose to change the gears myself based on what I am pulling. However, there are many out there that don't and just let computer do all the work. These are the people will generally have transmission clutch issues later on.
I'd call that design error - the input side of the transmission should always be sized for the max tq output of the engine.
Here're some charts I made a while back, 45 mph grade @ near full throttle. The 3.31 truck does it in 4th, the 4.30 truck does it in 6th:
The tq input with both gears are the same. In fact, the 3.31 is a bit lower, purely a fluke of course. At another speed the 4.30 might be a hair lower.
Point is, rear end ratio makes zero difference in RV application. In a commercial under-speed case, it may be difference because they're purposely lugging the engine down to 1100 rpm cruise. Whereas we're agreeing to lock out 9th/10th so both trucks cruise the same.
I am not sure if I would call it a design error and more like forced to in order to meet regulations. Most people think that longevity is the main concern for vehicle manufacturers. While it may be high on their list, meeting fuel and emissions regulations is priority number one since you cannot sell a vehicle unless you meet these regulations.
Many times, these regulations force the manufacturers to make things less reliable and counterintuitive to their purpose. From adding spent exhaust gasses back into the intake to reduce NOx, installing a less reliable VG turbo to better control the EGR flow, and even installing taller gears just to meet CAFE fuel requirements. The same thing happened in the heavy-duty industry when we had to turn to downspeeding in order to meet 2016 regulations. The manufacturers did not have time to do the research to see what effect downspeeding had on components and it wasn't until after a lot of fleets started complaining about premature driveline and clutch failure that they started to research it.
In the case of the OP towing 40k combined with his 3.31 axle, the truck's computer will put it in 10th as clearly seen in the video. My truck will put me in 6th even with towing close to 17k. We both are experienced enough to manually take out these gears to put less of a strain on our transmissions and driveline. However, most people out there have a "the computer knows best" mentality and lets their truck do all the shifting. It is these people that will generally have overdrive clutch issues.
Is this the fault of the owner for not being knowledgeable enough to know when to lock out gears? The manufacturer for being forced to make the truck this way to meet EPA and CAFE regulations? Or the EPA and NHTSA for forcing auto manufacturers to make trucks that are less reliable for their purpose?
I think you have a point regarding how the manufacturers have introduced poor design into their engines in order to meet EPA regulations. I also think those issues have been largely addressed. There is a possibility that poor driveline design is being forced apon us now but, I'd probably be willing to bet that my 2021 will be more reliable than was my 2003 but it is obviously to soon to tell.
While towing with 4.30 gears in the F450, high torque gets transmitted through the overdrive gears on every hill. So I would call it design error if the overdrive clutches of the 10R140 can't handle the full torque output of the Powerstroke at 2000 rpm.
