Grit dog wrote:
BTW, didn't watch the video until just now. Love the Ford dash setup!
But what stood out was it appears that either 9th or 10th gear is effectively useless at the speed you were driving (about 63-64mph).
Less than 100rpm split between gears at almost "highway" speeds doesn't really have nay practical benefit IMO. That calcs to about a 200rpm split at around 80mph, still not enough to write home about except to say you have the "most" gears!
I'm not one to bash on the "more is better" theory when it comes to trans gears, but unless there is a benefit down lower in the ratios somewhere that the 10th gear could have a greater benefit, seems like 9, or even 8 speeds is about all that is practical for a light duty diesel truck.
And in other news, your 34" tires have about a 33" effective rolling diameter. Based on a known final drive ratio, known trans gear ratios and the rpms and speed observed in the video. Not that it matters, just an observation.
Common thing really. My "37s" roll at approx effective diameter of 35" and the half worn "35s" I have on another truck roll closer to 33" (with low/no load, "comfortable" pressure in the tires for both trucks).
I agree 10 gears are more than what is really needed, especially with shorter diff gears. That has a lot to do with why I am for taller diff gears and saving 9 and 10 for running empty.
I had the cruise set at 101 km/hr .... just under 63 mph
According to Michelin's website my tires should turn 610 revs/mile which would mean the effective diameter would be 97% of Michelin's claimed 34.09" diameter... so exactly as you said ... 33".
And, based on a 33" tire diameter and 101 km/hr my tachometer should be reading:
2112 in 7th
1795 in 8th
1451 in 9th
1334 in 10th
I think when you know the rpm the tach is supposed to read when you're looking at it, it's easier to believe that it's accurate.
