egarant
Apr 14, 2013Nomad
3.42 or 4.10?
I am going to place my order for a 2013 Ram 3500 DRW Crew Cab Diesel tomorrow.......3.42 or 4.10 rear end? Putting a 1140 Arctic Fox on the back, towing a 5,000 lb boat or Toyota Tacoma from time to ...
RCMAN46 wrote:
If I were to buy a 2013 3500 Ram with the 6.7 and Aisin 6 speed it would be the 3:42. The 6.7 has more than enough low rpm torque to handle the 3:42 and you will enjoy the truck at light loads on the freeway with the 3:42. I am sure in the upcoming hill climb tests Ram will supply the 3:42 rear end and should be able to keep up with the Ford and Chevy with that combination. If they supply the 4:10 then I predict they will get their b&*ts kicked again.
