soren's avatar
soren
2014 Silverado 3.42 or 3.73
Hopefully some of you have a bit of experience with the newest GM trucks? As a bit of background. I have towed a considerable amount in the last 15 years, with roughly 1/2 dozen TTs and almost as many 1/2 and 3/4 T GM trucks. The issue here is that I'm buying a new 30' TT. The dry weight is 5600LBS, gross of 7500lbs. I would really prefer a GM 1500 Crew 4x4 to pull it with. My last trailer was about 1000lbs lighter and did well with a 5.3/3.73 older Tahoe.
Now that we are in a world of much higher power from the same 5.3 and things like 6 speed transmissions, I'm not sure what I really need? The issue is that trucks on the lot are typically rate at 9500lbs. with the 5.3/3.43 combo, and every dealer has a pile of them. The upgrade is the Max tow package with the 3.73 and roughly an additional ton of rating. The package is overpriced for what you get, and it's pretty rare. Bottom line is, what can I expect when pulling 7K or so, with the 3.43?
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 30, 2026
