CrashandBurn's avatar
CrashandBurn
3.5 Ecoboost towing 5th wheel mileage?
Read lots of reports of the great power of these trucks and mileage solo, but nobody talks about towing with a boxey fifth wheel.
My old Dodge Cummins always got 12.5 to 13.5 with my 29ft Golden Falcon.
I now need a truck mostly for solo driving, and short (300) mile camping trips. No more cross country.
I didn't think there ever would be a half ton that would handle this trailer.
  • N-Trouble wrote:
    A 5th wheel will go down the road with less drag than a bumper pull due to the aerodynamics. Just sayin...
    You can see as good or better mileage pulling a big 5er compared to a smaller/lighter bumper pull simply due to the difference in aerodynamics.
    I'll have to disagree with you on that one. A TT can have better aerodynamics than a 5er sticking way up in the sky. It comes down to frontal area. Wind is not your friend unless it's at your back.
  • mark5w wrote:
    My Eco Boost gas mileage for 2200 miles is about 10 mpg. Tows very easily both up and down mountains.
    Was that pulling the 2013 Crossroad Cruiser Patriot cf335ss??
    A 9790lb dry weight 5th wheel!
  • A 5th wheel will go down the road with less drag than a bumper pull due to the aerodynamics. Just sayin...
  • I saw a rig just like yours leaving Cherrystone when I was there the first full week of August. We went up to Castaways the following week. I remember seeing the F150 towing a fairly large fifth wheel and thinking man that has to be more than a handful. I'm starting to see more and more of them around so it must work out ok.
  • 720Deere wrote:
    Sorry, I can't help the OP with Ecoboost experience, but did you happen to be at Cherrystone with your rig in August, mark5w?
    No, was down at OC, MD in August.
  • If considering the Ecoboost for 5th wheels, order the 8200 pounds GVWR package!
  • My Eco Boost gas mileage for 2200 miles is about 10 mpg. Tows very easily both up and down mountains.
  • fla-gypsy wrote:
    Mileage towing with any gas motor will be similar regardless of power. 8-10 mpg depending on weight and frontal area, the only difference will be how easily it does it.
    this, x2
  • Mileage towing with any gas motor will be similar regardless of power. 8-10 mpg depending on weight and frontal area, the only difference will be how easily it does it.
