Hornnumb2ExplorerMar 09, 201530 amp Furrion inletGoing to install a Furrion 30amp inlet, should the rubber washer be good enough or should I add so butyl too? Thanks Michael
dmullenExplorerMar 10, 2015I used the round seal they included and then used some Pro Flex around the outside edge of the round metal piece.
Related Content30-amp Power InletFurrion appliances30 amp Furrion inlet and sewer hose compartmentFurrion Chill 14.5 & 15.5 unit's both use 15.4 amps?furrion 50 amp cover
