Hornnumb2ExplorerMar 09, 201530 amp Furrion inletGoing to install a Furrion 30amp inlet, should the rubber washer be good enough or should I add so butyl too? Thanks Michael
trail-explorerExplorerMar 10, 2015If it were me, I'd use butyl putty sealant and not the gasket, then some proflex around the perimeter.
Related Content30-amp Power InletFurrion appliances30 amp Furrion inlet and sewer hose compartmentFurrion Chill 14.5 & 15.5 unit's both use 15.4 amps?furrion 50 amp cover
