Grit dog wrote:
Jarlaxle wrote:
Yes: the potential repair bills have gotten MUCH larger! For the cost of a bad HPFP, a failed exhaust filter, or a bad turbocharger on a diesel, you can put a rebuilt engine in a gas truck.
While you're correct, the diesel component repairs you mention are more expensive or even something that wouldn't be encountered with a gas rig, it's a gross exaggeration to even compare the cost of replacing any one or even 2 of those components apples to apples with the cost of say replacing an entire engine in a modern HD pickup.
I could pay 3x as much for a part at the dealer and 2x as much for dealer labor to replace and compare it to pulling my own LS motor and getting it freshened up and re-installing myself, but apples to apples you're way off base.
Question is what do you want or need or prefer?
I can ride a bicycle even cheaper than a Ford V10...
I suspect you are attempting to make some sort of point here...but it's incomprehensible.
