jamesu wrote:
Because of quite expensive repairs on my diesel (see signature) it has got me thinking. I am half way contemplating trading for a 3/4 ton gasser. My diesel tows very well, so I am wondering: would a 3/4 gasser’s towing performance be comparable to my Duramax, or would it be more like a “beefed up” version of the 1/2 ton gasser I used to tow with years ago? On trips I am towing 8500-9000 lbs.
APT wrote:
Comparable, no, but more than good enough as long as you accept a little higher engine speeds.
The first reply hit the nail on the head, the right gas engine will do the job, just not at the same comfort level as the diesel.
I think the cut off for a gas TV is really around 12,000# beyond that you suffer from poor mileage, and slower speeds.
I moved from a 2001 Ram CTD, 5 speed and 3.55’s, I now tow with the 2016 in my signature. I can honestly say that I hardly notice our near 13,000# 5er when towing.
As to cost of maintenance yes newer diesels do cost a bit more, $110 for fuel filters every 15k, but I can also go 15k on an oil change, is that two or three times for gas?
I changed the 2001 every 10k miles, I had to replace the tappet cover gasket at 300,000 miles and the gallery was clean!
