troubledwaters wrote:
Why a 5th Wheel? You can tow a lot more TT with any given truck than a 5th wheel. Pin weight is double on a fifth wheel than the tongue weight of the same weight TT.
Well they naturally tow better, the physics of the hitch location does not create sway. They have more storage, many have huge basements, many will state you loose the bed of the TV, but stuff in bed needs to be loaded and unloaded every trip, the basement can stay packed. In addition they tow shorter about 4' to 6' shorter for a given length. Fivers are roomier with higher ceilings in most living areas.
Did I say they naturally tow better due to the physics of the hitch location.
