I am reposting this to make my question clearer. What I meant to ask see this :. I have a 42' fifth wheel with empty weight of 13,590. I am told by the dealership that my 2016 6.2 F350 srw Can p...
1. The F450 has a wider front end (wider track) and smaller turning radius. 2. The rear end gear ratio is lower on the F450. 3. The F450 has larger brakes (given same year models). 4. Depending on year and equipment, the F450 sometimes has a lower payload rating. This is due to the fact that the numbers on the F450 are calculated using the SAE J2807 standards. 5. Depending on the state, the F450 can cost more to register and insure than the F350.
