ticki2
Jul 12, 2020Explorer
If you have a load in the back the extra weight of the diesel will be beneficial because you will still have more weight on the rear axle than the front . If you are empty you will have more weight on the front axle than the rear and that will work against you . That being said there is not enough difference between gas and diesel traction to make that the deciding factor .
