_tpc_'s avatar
_tpc_
3rd row seat...payload capacity question
Just wondering if anyone knows this, does a 3rd row seat in a 2007 tahoe count against payload capacity? Lets say payload is 1800 lbs (I am just making up a number here) and the seats weigh in at 100 lbs (again these things are heavy but I am just making up a number).
Would the capacity still be 1800, or would it be 1700 now to accommodate the extra pounds for the optional 3rd row?
  • eluwak wrote:
    If you're pulling that number off the sticker on the vehicle then pulling the third row out gains whatever it weighs. That number on the sticker should be as delivered with a full tank of fuel.
    I did not think any payloads include a full tank of fuel.
  • Yes, if you take out the 100# third seat, you can replace it with a different hundred pounds of junk. 100# of weight riding on the rear axle is 100# of weight regardless of what it is (unless you load it with 100#s of pigeons and keep them flying all of the time).
    Bill
  • Great! Thank you all for the information. :)
  • MegaCab_PL wrote:
    Just like Eluwak said, if you read let's say 1500 # off the yellow sticker on YOUR Tahoe, it includes the third row seats. If you take them out you will gain that weight towards the tongue weight.
    X2
  • Just like Eluwak said, if you read let's say 1500 # off the yellow sticker on YOUR Tahoe, it includes the third row seats. If you take them out you will gain that weight towards the tongue weight.
  • If you're pulling that number off the sticker on the vehicle then pulling the third row out gains whatever it weighs. That number on the sticker should be as delivered with a full tank of fuel.
  • Every read the 'fine print' when payload, tow numbers etc are published?
    *May vary depending on model, trim and/or powertrain.
    *Weight of additional options, passengers, cargo and hitch must be deducted from this weight.
    YES.that optional 3rd seat will reduce payload as will anyone using that seat (or any cargo/stuff........as will ALL passengers plus any drivers weight that is more than 150#)
    Like suggested...weigh vehicle 'camp ready' (every body/thing in it) and subtract that weight from GVWR......pay attention to RAWR and Rear Tire Max Load Ratings also
  • Payload is a rating based on a generic optioned vehicle which can be significantly different than yours. To find your vehicles payload do the following math: GVWR - Actual Weight of your vehicle. Yes it's that simple. So if your vehicle has 100# less because the seat is removed then your payload is 100# more!
