Paul_V1's avatar
Paul_V1
4150 Happijac Bearings
I finally got some water intrusion into my jacks and the bearing are rusted tight for the jack screw. All of the other parts were cleanable and in good shape. My question is where can I purchase the needle bearings? Any help would be appreciated.
  • bcbigfoot wrote:
    I got the needle bearings and thrust washers from my local bearing wholesaler they are as follows
    brand name and part #: INA TC1018 Thrust needle cage assembly
    INA TWA1018 Thrust washer
    The bearings are approx. 2$ each and the thrust washers are 1$ each.
    (edited to corrected part number)
    Thanks for the part numbers and info. I found them and ordered from Grainger. I will be putting the jacks back together this weekend. Thanks again.
  • These bearings numbers also work for the 4600 series jack as well. Likely the 4500 also but don't know for sure I haven't had one apart.
  • I got the needle bearings and thrust washers from my local bearing wholesaler they are as follows
  • And, if needed, you can get a refurbished complete unit for cheaper than new.
  • You can get them directly from Happijac.. Search online for their website.
