Frjory's avatar
Frjory
4bt water pump part #
Can someone give me a Cummins part # for the water pump on my 4BT? It's a VE motor, cpl 767, 105hp. I picked up one at the parts store but it has different shaped fins that are plastic and exposed. I want to stick with the non exposed metal ones if possible. Thanks.
And off topic question. Ok I'm in the market for new sheets. I don't want to blow hundreds of dollars on something ridiculous, but I'm prepared to pay for value. I see 400, 600,800 "threadcounts", not sure the difference.
Also, blanket recommendations. I realize I've been borrowing a set of my roommate's for EIGHT months.
Incidentally my bed size is "twin", so it's bigger than a single but not as large as a queen size. I found some sheets on the comfortersetreviews, but want to hear few reviews.
    What rig is the motor in, and what are the details (and pics)? Closet gearhead nerd wants to know. :)
  • Cummins Quickserve:
    https://quickserve.cummins.com/info/index.html
    Put in your serial number and it will give you a bunch of information about your 4bt.
  • ShinerBock wrote:
    What is your engine serial number? I have Cummins parts and service access on my work laptop.
    I'm betting it's the same part number as the BT6 of the same era.
  • What is your engine serial number? I have Cummins parts and service access on my work laptop and can look it up for you.
  • Simply take have your engine serial number and take it to a Cummins authorized dealer. They can set you up. There is a tag on the drivers side edge of the timing cover.
    Or give Geno's Garage a call.
    Phone Order: (800) 755-1715
