marcsbigfoot20b
Jul 19, 2015Explorer
lt1tyrell wrote:
Yup I know it is a 4l60 with a tv cable. Already has a big cooler installed and a gauge with the sender in the pan. It works great other than the fact that I can't keep it locked.
Ok that changes things, lol.
Check into the throttle valve cable adjustment procedure for that truck and see if that helps.
Other than that or TCC solenoid flaking out, you are only making about 190 hp at the crank with that TBI motor.....I had a 93, it was weak.....had to mod it and eventually get a bigger TV.
