Turtle_n_Peeps
Mar 22, 2015Explorer
Depends on what is wrong with it.
There are several things that can cause what you are experiencing.
First thing I would do is pull the dip stick and smell the fluid. Does is smell burnt? If not, more than likely it not a clutch problem.
Next thing is pull the pan and look for metal. If it's all metaled up a hard part failed.
If the governor bore is all garffed up you will need a new case or put a bore saver in the case. At that point I would get a new tranny.
First things first. Find out what is wrong. :)
