- PA12DRVRExplorerDifferent year, different model, same mfg, same problem....both a position sensor switch and related solenoid went bad overnight: lever moved fine, nothing happened in the innards.
Straightforward fix (doesn't mean inexpensive) at the local tranny shop; most challenging part was getting the vehicle out of the condo parking lot. Ended up with a "come back at 10:00 p.m." charge from the wrecker as well as a couple of PO'd neighbors since it was unavoidable to block one road for about 15 minutes. - PA12DRVRExplorerDifferent year, different model, same mfg, same problem....both a position sensor switch and related solenoid went bad overnight: lever moved fine, nothing happened in the innards.
Straightforward fix (doesn't mean inexpensive) at the local tranny shop; most challenging part was getting the vehicle out of the condo parking lot. Ended up with a "come back at 10:00 p.m." charge from the wrecker as well as a couple of PO'd neighbors since it was unavoidable to block one road for about 15 minutes. - TerryallanExplorer IIIt's broke, and needs repairing at the dealer, or reliable trans shop
- Grit_dogNavigator IIIProbably a toad and the electronically actuated transfer case won’t shift out of neutral.
No , don’t know what’s wrong. Bad switch or bad solenoid are the 2 most obvious issues though. - LanceRKeysExplorerWill the shift lever move and nothing happens or is the shift lever stuck?
- KD4UPLExplorer IIThat's an impossible question. What year are we talking about? Are you asking about neutral in the transfer case or the transmission? Manual transfer case or electric transfer case? Manual transmission or automatic transmission?
- LwiddisExplorer IIWhile lacking your truck’s year, there is no need for posting help or support.
- LwiddisExplorer IIYear?
44,056 PostsLatest Activity: May 04, 2014
